- Dołączył
- 26 Maj 2010
- Posty
- 23498
- Reakcje/Polubienia
- 71955
Air Explorer 6.0.0
Air Explorer 6.0.0November 20, 2026
- New Windows 11 style design with light and dark themes: refreshed tabs, lists, menus, toolbars and icons throughout the program.
- Added support for Filen.
- Added support for kDrive (Infomaniak).
- Refreshed windows: Options, Sync, Scheduler, Search, Accounts and most dialogs.
- iCloud: more reliable sign-in.
- Compatible with more SFTP servers.
- More file types accepted for the SFTP private key.
- New screen for adding accounts, with a cloud search box and the most popular clouds highlighted.
- The scheduler shows the last result of each task, lets you open its latest report and can sort the list by any column.
- Renaming or creating folders now follows the encryption settings.
- Google Drive: uploads no longer create duplicate files.
- New Google Drive duplicates tool. Open it from the Google Drive account settings, choose a folder, click Analyze and decide what to do with each group: keep one copy or merge the folders. Nothing is deleted permanently. Everything goes to the Google Drive trash and every change is written to the log. It is also available from the command line with deduplicate.
- Large synchronizations use less memory and CPU.
- New “Copy as command line” option: in the transfer queue, right-click a task to copy the matching command and run it again from the command line.
- Fixed high CPU usage when refreshing folders in some cases.
- Fixed errors in transfers from Box to Google Drive.
- Google Drive and OneDrive use less memory.
- Box uploads are faster and handle server limits better.
- The list of items in a synchronization can be exported to CSV.
- Google Drive: duplicate folders no longer appear.
- Degoo: fixed downloads of large files.
- Fixed unexpected crashes.
- Folder trees now scroll horizontally on their own when you open deep folders.
- Google Drive: copies made on the server are no longer named “Copy of…”.
- Google Drive: shared links are no longer made public.
- Huawei: fixed uploads of 0-byte files.
- FTP: fixed upload errors.
- More detailed Amazon S3 sign-in error messages.
- High contrast mode now uses the system colors.
- Updated translations for all languages
