Exclusive Torpedo technology
Highly realistic speaker simulation is achieved by use of convolution. Two notes started from that technology and brought it much further, to accurately reproduce the characteristics of the whole miking chain (speaker, microphone, preamplifier, studio room acoustic).
Many parameters influence the sound of your guitar or bass rig when it comes to recording. Taking good care of the cabinet selection and miking will dramatically improve the sound of your takes. The Torpedo simulation reproduces the tiniest variations of a cabinet behaviour such as frequency response and distortion. Move the microphone in the virtual studio room thanks to the Torpedo
synthesis, control the phase with the Variphi: all the settings you need to achieve great recordings are here.Until the 30th of April 2020, download the plugin and receive a lifetime license containing two Virtual Cabinets.
The cabinets are the Brit VintC (inspired by a closed-back Marshall® Slash Signature 4×12″ with Celestion® V30 speakers) and the Watt FanC (inspired by a closed-backHiwatt® 2×12″ with Fane speakers).
SPECIFICATIONS
- Mix up to 20 cabs inside a single plugin instance.
- Stereo processing
- 3 plugin sizes (S, M and XL)
- Presets are compatible with all the Torpedo range of products
- Browse, listen to, and buy the cabs you prefer directly on the in-app, integrated Boutique.
- The plugin will check for updates — of course you will need Internet access for this functionality to work.
- Shortcuts available to speed up your workflow while working with the plugin
