Synei System Utilities
Synei System Utilities to bezpłatny pakiet narzędzi przeznaczonych do kompleksowej optymalizacji, naprawy, oczyszczania i konserwacji komputerów działających pod kontrolą systemów Windows.
Optimization you can actually feel
Built precisely for maximum optimization. Compare with other optimization software and experience how our product makes your computer much faster.
Feature icon Defrag your hard drives
Reorganizes files in your PC's hard drives, so the files are systematized, which helps your PC achieve tasks quicker.
Feature icon Customize to your preference
It's highly customizable. Choose from multiple designed themes or create your own! Easily choose your desired settings to desired color.
Feature icon You won't even notice it running
There are many similar programs out there that not only constantly nag you with annoying pop ups or advertisement, but they also use up huge amounts of background resource. You'll never get that from us; our programs are very light on resource and nag free.
Feature icon Several Utilities on a simple interface
Whatever utility you need, it's always there, whether you need disk cleaning or backing up. Don't bog down your computer by installing several different utilities.
Feature icon TuneUP Your System
Boosts your system and internet. It automatically modifies your registry settings for quality performance, so you don't have to worry about a thing.
Feature icon Don't want to install? No problem!
We offer both the installer and portable version. Portable version lets you run the program without installation. You can also take it with you and load it from anywhere, such as on a USB Drive.
Feature icon Absolutely FREE!
Why pay over $40 for similar products that barely do what they claim? Our product is absolutely free and we stand behind what we claim. In return, if you like our software, all we ask is for you spread the word.
Synei System Utilities 2.00
PC Cleaner, Startup Manager, and all other programs updated for much better experience.
Few first-run tutorial to help user learn how to use System Utilities.
Updated definition of all the programs.
Synei System Utilities 2.25
Include updates for many programs such as PC Cleaner and Startup Manager. The updates includes better performance and bug fixes.
Other Bug fixes + Stability improvements
Synei System Utilities 3.00
Includes PC Cleaner v2.0
Improved cleaning, optimizations, and security.
Windows 8 users no longer need to install .Net Framework 3.5
Exciting new features/programs
Interface updates
Bug fixes
Many more!
Synei System Utilities 3.40
Much better compatibility with Windows 10
PC Cleaner: Better detection and cleaning
Service Manager: Windows 10 services added
Service Manager: Better optimizations
Startup Manager: Better detections of unwanted programs
Other minor software updates
Bug fixes
Many more!
Synei System Utilities 4.00
New tools in the "Tools" section
Task Manager, Force Deleter
Turbo Mode - ReApply every 30 min
Deep Cleaner improvemets and "Big File Scanner" mode
Update of other programs like PC Cleaner, etc.
Update definition of all programs
Introducing Referral Program
Tons of stability improvements and bug fixes
