Nowetesty MRG ( Malware Research Group Project 025 )
Dziwny ten test
mam na myśli SpySheltera
"Next pains titled “how to explain why I clicked Allow suspiciois action” while testing, if you don’t see difference between bluepoint exe and suspicoous exe, congratulate, even if you really don’t see this difference then read some help before you start using it there is an tip inside help
“- Do not allow programs to run if they exhibit suspicious behavior. When you are not sure about the program, it is recommended that you first block it from operating. If it does operate and your system remains stable, then you can remove this application from the black/white list and allow it to operate in your system.”
SpyShelter passed this “test” without big problem but it’s not strange that you marked it as failed if you clicked allow actions for SOME reasons
