Program do czyszczenia rejestru, defragmentacji i tworzenia kopii zapasowych
Advanced Registry Care is a powerful optimization and maintenance tools for Windows Registry. It has a clean interface that’s easy to use and it helps you to scan, clean, repair, defrag, backup and restore the registry. It supports both 32-bit and 64-bit windows systems, and will observably boost your system speed. It is very simple to use, even a child can handle it by a few clicks, never mind the knowledge of registry.
